CMF_Marshal
» CMF Memberwhere can i get some clear tail lights for my 95 micra
cheers
cheers
1300supers WROTE:
"one of them is break? how much u want for them?
can i use the origin bulbs in that ones right?
deNs WROTE:
"1300supers WROTE:<BR><BR>"one of them is break? how much u want for them? <BR><BR><BR><BR>can i use the origin bulbs in that ones right?"</DIV><BR><BR>It's not the bulbs that you should be worried about fitting (as they're all universal and use bayonet fittings) but rather it's the bulb holders that can differ a LOT between types of rear clusters. Make sure yours match that set before you decide to go for some as you could be stuck with a set of clusters without a way to clip the bulbs into it.<BR><BR>I think those ones may well be ones that take the jap holders, but easiest way to see if they'll fit or not is to look at your current light clusters with the bulb holders out and see if they look exactly the same at the back.<BR><BR>---dens
