hi again,
i am sorry that my thread is again about problems, but problems are to be sorted
when i start engine and rev it, it goes back to idle fine.
when it has proper temperature and i do whatever i want with throttle on neutral or clutch, goes back to idle fine
when the engine is heated properly and i drive say 50 kph on 4, 2000rpm, engine under medium load.. i then lift throttle and press clutch.. engine revs up to 3000rpm for a few seconds, then returns to idle.. higher load, longer time
when the needle just leaves L mark on temp meter, it revs too, but only a little
when there is no load, e.g i rev it on neutral, no problems..
is it autochoke? i remember, last time i checked the butterfly, it was in one position, i touched it with my finger and it opened fully.. then i could move it freely as i wanted, not much resistance at all.. vacuum valve controlling flap is ok..
engine starts ok when hot and also cold (20 deg C)
it did this to me once, after i was messing with carb, replacing hoses, cleaning it.. then after 2 weeks it stopped when i was messing with carb again.. now it of course started after i cleaned the carb from the inside and outside etc
i read about autochoke in these forums, but problems were connected with starting when hot - not my problem.. also found guide from one of the members about checking the flap when cold, then watching it open.. did not have time to do that yet, will do tomorrow or this evening
thanks a lot
thanks a lot
