ok as some of you may know i was having trouble starting my march, it starts if i have the ignition on and i run a wire from battery positive to a 10mm nut on the starter.
While the car was running i tried turning the ignition to engage the starter, usually on a normal car it would make a horrible grinding noise, but instead my ignition puffs out a bit of smoke, i presume this isnt good, but could somebody tell me what is causing this?fwn
