jabran200
O.k can you guys give me your oil temperature and pressure readings? I think I am not getting correct values for both pressure and temperature. I will properly check once i am sure they are fitted correctly but would be nice to have values to compare to.
Also when i connect a multimeter (one on positive and the other one on the sender's signal wire) and got about voltage for oil temp which increases as the car was warming up and the the pressures was showing a decrease in voltage as i put my foot on the throttle.
thanks guys any help will be greatly appreciated.
