what have you used to get the window to stay on its regulator in the clips Thanks in advance Dean
D Deank11 Jan 4, 2015 #1 what have you used to get the window to stay on its regulator in the clips Thanks in advance Dean
frank Club Member Jan 5, 2015 #2 Deank11 said: what have you used to get the window to stay on its regulator in the clips Thanks in advance Dean Click to expand... 2 pack glue dean, and key the surfaces first
infinity Jan 14, 2015 #6 Windscreen glue is acrylic sealer putty i think. Anyone care to correct?? Cos i aint sure
S Steve Hastings Jan 15, 2015 #7 Windscreen glue is a type of urethane use it with a primer on the glass and clips leave it for an hour to set and it'll never come off again
S Steve Hastings Jan 15, 2015 #9 Yeah but the only way is to cut it other manufacturers use this method to fix fittings onto door glasses
