will the GA15DE Throttle body fit my 1996 micra.
i have the 1l 16v micra and im getting the well known idlin symptons.
does anyone know if this throttle body above ressolves this problem.
if so were can i purchase a reconditioned one and how do i fit it.
can anyone help.
thanx
hi
hi there i have the soldering diagram cheers.
i was just wondering if the will the GA15DE Throttle body will fit my 1996 micra and how easy is the job to do by myself.
thanx
the only one I can say "fits" is the GA16
But it's too big and connections need to be removed as they hit the injectors causing it to idle poorly.
The soldering works perfect.
thanx
yes, they are a direct fit (and the same size as the ga16 one) IF you can find one in the uk :)
