Hi, my 2003 Micra SE runs fine most of the time, but every so often the immobilizer doesn't turn off and I'm unable to start the car.
I've read that this could be down to interference. But I have found that disconnecting and then reconnecting the battery seems to sort it out. Also If I leave it for a while and try again it will start OK (must pick up the key fob signal).
What I want to know is if I wire up a new momentary start switch, with it's own separate wiring, with one going to the battery (with an in line fuse) and the other one to the small wire on the starter. would this work OK or could it cause problems.
I would only use it in case of the immobilizer not picking the key fob signal up. I've read other people saying that when they have had the same problem, their car will start with a bump, so I'd think an extra switch would solve the problem and save me from having to set the radio code and the computer up each time.
My main concern is, if I left the original starter wire going to the small starter terminal, when I turn the new starter button on, could it damage the relay on the original wire or anything by sending power up the original wire.
Would my new starter button only work well If I disconnected the original starter wire?
I've added a small diagram I've drawn up...
