NiteSite said:i have same problem i think noise goes when i put foot on the clutch gets worse as i accelerate, but dissapears in higher gears. someone told me it was my thrust/release bearing in the clutch
MTB said:2nd hand one would cost you around £80 upwards, .
IMPORTANT: - Please ensure your reply is constructive and adds to the discussion
- Pointless posts will be removed and may result in you losing posting privileges
i dare to ask your opinion if i was to here my brakes grinding as metal hits metal.
i seriously shiver at the consequences.
please dont advise people to ignore problems. by turning up the stereo.
hughes_16v said:i dare to ask your opinion if i was to here my brakes grinding as metal hits metal.
IF THAT WAS AIMED AT ME...
its called a joke mate, and if ur brakes made that noise id serioulsy suggest u change ur pads before u start welding.
i have a ABC DIPLOMA, ABC CERTIFICATE, LEVEL 2 PROGRESSION AWARD IN MOTOR VEHICLE STUDIES
p.s iv found out the induction kit on my car makes the whilsling sound not my clutch as i replaced everything in there when i pt my new clutch on just before xmas, take my induction kit off it dont happen
Ed said:Alternator bearings can also do this. I had one that sounded like a supercharger once.
Ed
