hi all new to this forum,i like all the helpfull info on here its a credit to all you members
I was wondering what is the widest wheel that can be fitted on a k11 with corsa coilovers on it
cheers
cheers
I really don't think corsa coilovers would make any difference to the width, If anything you can go wider with higher offset, meaning you can go more inside because they are narrower then stock micra towers.
You can try willtheyfit.com to compare stock/current setup with the one desired one.
