Wheel size mistery solved
Hi guys,
Just fitted 17x7j ET45 wheels with 215/40/17 tyres on my 160 SR..I think I have discovered the upper limit for wheel dimensions without any separators or strange mods.fit perfectly and wheel is within the arch (no margin)
John_D
Radio Code Guru
Hi guys,
Pictures?
Hi guys,
Interested to see what it looks like to be honest.
Pictures are always welcome
I ve ran 17x7 ET37 wheels with 215/45/17 tyres.
Swapped them out for a good summer set.
17x7 ET40 wheels with 205/40/17 tyres and a 5mm spacer on the rear.
And my winters are
16x8 ET30 with 195/45/16 Tyres.
Also with 5mm spacers on the rear
All with at least 30/30 lowering and the winters probably 50/50.
no rubbing arches or tires even with steering.
There is never a limit.
Depends how crazy you wanna go.
If you wanna go a little wider, but stay within the arches ET40 is perfect. Or in your case use 5mm spacers on the front and the rear.
Verstuurd vanaf mijn SM-G950F met Tapatalk
Yeah, pictures please? ;)
Thinking of rims below in 7.5x17, 4x100, ET42 to my vehicle :rolleyes:
This is handy and in Finnish, Tire size calculator
Vanha rengas = Old tire
Uusi rengas = New tire
Nopeusmittarin virhe = Speedo error
Renkaan halkaisija = Diameter of tire
Renkaan ympärysmitta = Tire circumference
