What tyres would you recommend?
165/70R/14 is the size I need, so far the best tyres I've seen are just shy of £60 a pop.
Eco Contact 5
Improved tyre performance in key areas over Conti EcoContact 3 - Handling, Braking, Wear, Comfort, Reduced Rolling Resistance.
Designed for drivers who cover higher mileage but also provides lower CO2 emissions and improved fuel consumption. Redesigned sidewall leads to improved rolling resistance.
Better wet performance with improved grip and short braking distances.
Fuel Rating B and Wet Grip B 68db
I've noticed that the current tyres that came with the car are awful in the wet, you can feel the rear letting go on almost every roundabout, in the rain. This is at normal speeds, I'm no speed demon. In the Dry they seem alright.
What would you recommend?
MaxK11C
Micraless
Moderator
Social Brand Manager
Sounds like a good choice.
Personally I cannot recommend Michelin PilotSport 3's highly enough, if they do them in your size I'd recommend you take a look!
