Weber carb
Hi, I have a clio1 1.4 rt standing in the yard that I am breaking... It has a weber 32 drtm carb, which I could adjust so it would fit my ma10 :p
BUT it is quite some work, and I would like to know what you guys think of this ?
My main concern is, will I be able to set it up properly (idle speeds and low revs...) ?
Any advice would be welcome...
I know kev once tried a twin weber, why didn't you get it set up properly, what was the problem ? (and do you still have that intake manifold ?)
Thanks !
Ne1LL :grinning:
N
Pietro, how is that twin weber 36 setup of yours ? Any starting problems ? Does the car need to heat up before you leave, or is it the same as before ?
And how about idle speeds, did you get it set up properly ? Does the engine keep running ?
Really interested in this :suspect:
Thanks !
Ne1LL.
pietro
Twin carb is made by AM Tuning specifically for the Micra. It satrts first time every time, sometimes when cold is needs a little choke but can always be driven at once.
