Wanted non squeaking front wiper linkages
I know that feeling. Had it the past few days. I use cv grease. It seems to work well :)
Wd40 or 3in1 oil sprays might help for now
Well stripped it all out but the two spindles are shot..... took off the circlips and sealing rings ... tried to free up a bit .... but dead...... so all i am after is the two triangle spindle pieces that the wipers fit to (white plastic triangle with spindle to drive wipers going through it)
If any one has them ?
Did try to get spindles out of plastic housing but after hitting it with a hammer quite a few times i think its more likely i would break the plastic housing.....
Well I am going to call it the Magic Micra.
I turned on wipers today and all there is is a tiny squeak ... so i guess all the silicone lube, oil and grease has worked its way in overnight ...... result :)
