Volt meter
  • Thread starter Deleted member 29304
  • Start date
D
Hi All, I have noticed alot of modern cars don't have voltmeters fitted, i fitted a voltmeter to my 2CV which was easy but to fit one to my K11 is different where can I fit it? has anyone done this to a k11 already.
Yours Peter0003
Easy peasy m8 just use amutlymeter find the switched live on hte ignition swith solder in a wire to the poss on the voltmeter and simply connect the other terminal to earth then it will work on hte ignition swithc for you...illumination if it is an analouge version will need to be connected to the side light circuit
Dave
Don't have a permanent volt meter, but one of these is ideal to check battery condition/charging function, just plugs into the cigarette lighter socket and has the advantage of being able to be used on your other car(s) ......
