Urgent info required on works nissan k11 1.3 engine specs
A little info from a Greek site,
Nissan Micra Kit Car Specifications
Activity: (1997-1999)
BHP@ RPM 155/7950
Torque (Nm)@ RPM 142/6000
Length Width Height 3705.1740.1430
Weight (Kg/BPM Ratio) 790 (0)
Transmission 6-speed Hewland
Engine Type I-4
Engine Position Front Transverse
Engine Capacity 1275
Engine Bore 71
Engine Stroke 80.5
Engine Compression 11.1:1
Engine Valves 16
Engine Cams 2 OHC
Engine Carburation 8 Injectors
When warm my engine produces comps of
No:1 = 228psi
No:2 = 230psi
No:3 = 229psi
No:4 = 231psi
The guy at the garage thats setting my engine up has teste it using two different snap on comp testers and he says he's never seen compression like it on a 1.3
Engine specs are:
Port polish -1.1mm skim flat face valves custom made
Tri-angled valve seats valves have wasted stems
New 1.0 cg10 pistons
L and b crank and flywheel
Autosprint 260 duration 10mm lift cams
Baffled sump
R1 carbs
Genuine micra kit car exhaust
Inlet and exhaust manifolds ported to match head perfectly
Genuine micra kit car plastic cam cover
sounds like more than 11.1:1 to me, and those cams are very aggressive, so the inlet closing event is about the same as stock.
so 230psi sounds about right to me :)
I'd be we'll happy with over 130 tbh but we'll see may run a little no money sweep on the out come see who guesses closest could be fun
BHP@ RPM 155/7950
Engine Type I-4
Engine Bore 71
Engine Stroke 80.5
Engine Valves 16
Engine Cams 2 OHC
where can i get one of these? lol
