Tyres? Wheel tracking??
Gurpreet
Basically I noticed today that my front tyres are worn from the outter edges... the rest of the tyre is fine and has sufficient depth but the outside edges have worn badly...
come on... what needs adjusting?? and how much am I looking at?
kwik fit job?
thank youuuuuu
ollyc98
You are cornering too hard. Tracking usually affects the inner tyre.
However get your tracking done anyway as it's cheap enough.
Have you got aftermarket alloys on cos the offset could be wrong.
OP
OP
Gurpreet
Gurpreet
standard steelys.. hmmm ive only cornered hard twice.. surely thats not enough to take all that rubber off... but thanks.. yeh i shall go ahead with it.. someone was saying the 'camber' may be out.. dunno what they ment
frank
usually if the f/wheels are toeing in too much it,ll scrub the outside of the tyres, too much toe out will scrub the inside ! manual does,nt give setting but local tyre fitters will have a chart
pjg1979
THIS IS MY BOOMSTICK!
If you drive at 20 - 30mph can you hear a rubbing kinda sound from any of the wheels, I noticed that my front left wheel is rubbing and looking the the haynes manual it's the tracking.
