alfantasti
Club Member (Trial)
Recently had my 1.0 '98 steering gear and suspension checked for wear and freeplay and everything was tight and in good shape. Still notice that at motorway speeds stability is a bit unnerving. Had a four wheel alignment check and even though the front wheel toe was within manufacturers specs, it was right at the lower measurement. Could anyone advise me if i had the toe-in increased towards the top end of the scale, would this help out the stability problem? By the way the Haynes manual suggests between -0.5 to 1.5mm total toe and mine is sitting at 0mm.
