B Bennai Guest Oct 24, 2005 #1 Titch what parts did u use to relocate your air filter to where it is now??,
Titch Micra K11ng Oct 24, 2005 #2 An ITG filter, and two samco blue hose bends. With a polished steel pipe. Got a coolant relocation kit also, so it sits on the other side of the engine now.
Titch Micra K11ng Oct 26, 2005 #4 Ys - a new tank, with a extended hose that runs to the radiator cap now. The lid of the tank also has a pipe in it so that coolant can be sucked up it
OP OP B Bennai Guest Dec 5, 2005 #6 titch, the 2 samco hose bends you used, wot were they?? degrees and diameters thanks
Craig Unofficial Member (Gold) Club Member Dec 8, 2005 #7 70mm diameter, you will need at least one 90 deg bend
