Timing
pork
I'm getting a bit bored of my 'safe'map,
And yes, a pro should be employed.
But that aside, what's people using? Around the 0.5bar area
frank
yes cruising in 4th @ 48 deg, then floored it and it instantly dropped to 18 deg, but i ran the driverside wheel through a puddle and lost traction for a sec (hence the dip to 25 deg towards the end)
frank
up to you i guess mate :) iirc baguette was running some negative timing for years (x deg atdc, with zero engine blowups) during peak torque, but he ran 1 bar + i believe,
Where is baguette gone these days?
Sent from my SM-G900F using Tapatalk
OP
OP
pork
pork
I've had a tweek of my map and using this for now......unless there some obvious mistakes
(I Know I need it done properly)
OP
OP
pork
pork
Yeah mate, more power straight off, dips off towards the higher revs a bit, but feels like there's more to go.
I get 7psi at about 800 rpm lol
Il use this for a while and see how it goes.
Here's the auto tuned fuel map too
