The right turbo?
Hi I've got an opportunity to get a reaaal cheap turbo, a GT 1749 is that OK for a 1.0 Micra and later for a 1.4? Will it need an exhaust wastegate or anything else?
YUHUUUUU!!!! looks like im getting a turbo hahaha chuffed atm ill get some pics up now, I know ill need a blow off valve but will i need an exhaust wastegate specially put in? not sure if im explianing right. ive seen some 4 cylinder engines with 5 exhaust tubes when turbo, whats that? gonna do some research
Pics
Thing is it has an actuator, so if there no wastegate what's it connected to? I haven't been able to find anything online about this turbo. Its a GTA 1749v
Damn, is it worth keeping the turbo or going for a different one? I'll be using a megasquirt ecu, can't find anyone who has tuned variable geometry turbo system though
Yeah, I'm looking at maybe locking the vanes open or adjustable by cable until I find a sweet spot. I would like to try and control by vacuum but its pretty complicated
here,s a vid of an actuator through the gears, works pretty much like a w/g eh, held shut till about 2k then jerked open and then relaxed a bit
