switch
how difficult is it to replace headlight combination switch, my local scrapper has a couple in stock mine on the car works fine but on headlight flash only one side works so i think i will try and replace it if its not difficult,cheers
It's easy peasy, just a few screws on the cover behind the steering wheel, then it slides off or has a few more screws. Check that the new switch is the same as your car before buying it, because there are 2-3 types and they're not interchangeable.
cheers and thanks a lot will have a look and give it a go.
