Suspension Arm OSF
Hi Guys,
Can any one put a name to this part please? The car failed MOT on suspension arm so im looking to replace myself. On casing the job i see this part is a little worse for wear so thinking about changing when i change the arm, but not sure what part it is to order, im assuming its some sort of bush?
Kind Regards
Try this web site, you can locate your precise model and engine, look at the schematic then you will have a description of the part you are looking for together with a part number which you can then order from a auto dealer.:unsure:
Thanks for this, handy site!
