Supercharger problem
How do you mean it don't work? Is it still got air flow? Disconnect the pipes and rev the engine and see if air comes out maybe? Belt snapped? Bypass valve broke? Lol
Never worked on a super turbo so just guessing :D
I will try it. The one that is on the sc. I think the problem is in harness but i dint know the exact diagramm or where to look...
yes mate, there are slip rings inside i guess, maybe not making contact ?
you could try a 12v feed to test the clutch eh :)
i couldnt find time today. the only that bothers me is that even if the charger got power, the green light in the dashboard always worked. now its like there is no sc circuit, like a fuse or relay is off.
hope so. a month ago when a harness plus was not working properly the sc didnt work but the light was on when should. thanx for the support
