Are you sure it's dipped towards passenger side.
Maybe you should check the engine and gearbox mounts..
For a 2002 micra k11 the mounts may have worn out or at least one or two of them.
Normally if you were to check this you are looking for excessive movement it should wobble about and not feel connected to the body of the car at one or more areas depending on where the problem is if this is the case.
Sent from my ASUS_T00P using
Micra Sports Club mobile app
