Steering wheel boss problem
I've used the search for this but still couldn't find any answers to my problem.
I bought an aftermarket steering wheel & a Micra HKB boss kit but when I tried fitting it today I noticed that when I tried to get the boss on there's no little hole/space on the back of it for the indicator cancellation pin to fit into and this is causing the boss to be about an inch away from actually fitting onto the spline. :/
Is there any way around this or will I need to find another boss that'll fit onto the indicator cancellation pin, or even if there's a boss from another car that'll fit? and if so does anyone know where to get one?
Put some nail varnish on the tip of the pin, then put the boss on as normal (don't shake or wiggle it) apply a little pressure so the varnish transfers on to the back of the boss
Remove the boss carefully and check to make sure you've got a dot of varnish where the pin should be, now you can mod it in a similar way to the original steering wheel cancelation thingy
