first check none of ur brakes are binding more than each other cos that causes the car to steer slightly towards the side with most binding/braking.
if you've lowered the suspension, you need an adjustable panhard rod and centre the axle to the chassis (both wheels are evenly spaced from the chassis panel)
if the axle is skewed offset, the rear multi-link setup means that both rear wheels would be pointing a fraction off-centre depending on how much it's skewed
the stock front castor geometry is what self straightens the front wheels relative to the car and can't be adjusted easily.
the adjustment of the steering rod ends mainly affect just how much toe and scrubbing the front wheels have and what angle the steering wheels at relative to wheels direction (ie car drives straight but steering wheel is pointing at 11clock/1clock)
^tis not a definate explanation but just from what i find
