ss dial lights
andy88
ive just got some super s dials (thanks daveeeeee) and i want them to light up red, was looking at previous threads and its mentioned that there is a green film and it was said that it wasnt removable but it is and easily, there just green domes with white tops that just pull off. pic attached.:)
are the bulbs 12volt? if is then i can go and get some red leds and resistors.
That's not what people are referring to when they say 'green film'. Behind the dial faces, speedo, temp, petrol, they're mounted to a thin green sheet.
I've got very bright red led's fitted to mine
with these green domes on a normal bright led can bearly shine through, without them you can see them lighting up
heres a pic of them with just one led in each light socket without them domes on, as soon as i can get some more leds they should light up quite good
i see what you mean about the film on the back of the dial face, only just noticed.
