Springs Question?
Tried using the search function and failed :oops: so here goes,
I have got a full set off Matiz Springs and Front Shocks, a Set of Civic springs and also Corsa rear shocks. Now my question is Which Springs and Shocks are best to use and What needs doing to them to make them fit? Sorry if this has been repeated couldn't find out what I needed :rolleyes:
Thanks Gaz
The corsa b rear shocks need the bottom bush trimming down and a smaller bolt (can't remember the size of hand)
For the matiz set up the k11 top mount bolt hole needs opening up and the lower bolt holes need slotting (again not sure on how much)
