daveeeeee
ok, have edited this as i'm more worried now, as i think it may be the headgasket. the carbs are up and going i got hold of a new gasket but there is an issue, it seems to be spitting from the exhaust, it looks like its spitting oil as its black but its not very viscous, its like black water. this was happening before but i asumed it was the leaking inlet manifold gasket. it only really does it with short sharp bursts of the throttle, i've just changed the oil, flushed and changed the coolent. theres no whistles or knocking coming from the engine everything sounds fine, theres also white smoke coming from the exhaust, but i'm slightly confused is because i havent run the car properly since the carbs have been on just reved it up a few times?
also, one for speedle this, where you running the carbs with the timing advanced? if so how much did you advance it?
cheers
cheers
