I used double sided sticky foam, it's good strong stuff but a cow bag to clean off if you ever wanna remove the strips. You can get it in pretty much any autofactors i think.
+1 for the sticky foam, get proper green backed stuff though, trick is to gently heat it up so the glue goes tacky, that way it won't fall off. With regards to removal there is a special drill attachment available for removing it too. It's like a big circular rubber, bodyshops use them, but you can get them off ebay.
