kennierobo
Buy & Sell Member
Some of you are aware of the si project i have going on well its all but done exept another stumbling block this time the side lights , now bare with me a moment, the looms are from a 1995 super sport or s/r and the dashboard and switches were from a P reg shape got that bit. Now its all fitted into a 1999 1.3 SI, First stumbling block was the hazard switch the plug would not fit not a problem easy solution get the right switch, however after wiring the lights and indicators I noticed the side light bulbs kept blowing why....then I noticed the heated rear window switch light was on when i switched the side lights on. dilema is this switch also no good for the loom I have it fitted to, it also sports a seperate rear fog switch as in early micras. maybe if I sorce a early heated window switch it will solve it has anyone got any other ideas there is no wires touching and no bad earths
