Sensors between font bumper and radiator.
Hi, i removed this weekend the front bumper on my wife's 2014 Micra K13 facelift. I found two wires hanging i i don't know what they are.The missing one i assume is the outside temperature sensor as currently showing -2deg in the dashboard.
Can you help? Where are they supposed to be fixed to?
Hi there,
The one that you are holding in the photo is the outside temperature sensor (it would probably display -30° if it was missing), and the other loose cable you show I believe is for the parking space measuring system fitted to tekna models, however they fit the same wiring loom to all cars to save on cost.
Hope this helps
Sent from my XQ-AU51 using Micra Sports Club mobile app
