sensor parking brake
h701micra.
What do you mean by "not fitted".
This means that it is not possible to install the sensors in the micra because they are incompatible or it means that you never install it in the micra.
lucas
Hi again.
Finally I bought the parking sensors and i am going to install them in the micra K13
I need to put the cables inside the car from outside where the sensors are. Anyone knows which is the best place where I can do this??.
Lucas
don't most people put them through the boot hatch.
attach to the bumper, hook the wires over into the boot and secure under the plastic trim
h701micra
Deactivated Account
I drilled small holes in the bumper and put them through there. To then go straight back into the boot floor via a little hole. That way the wires will hide under the carpet.
Don't know how/if you can do it but that's how I did it :)
