screwed !!!!
Hi All, Does anyone know where I can get a new screw for the rotar arm on my my K11 as mine has no method of being screwed back on again as I wore out the cross head on it whilst unscrewing it? Can I replace it with any screw of the same thread & size? or does it have to be same type. Can you help ?????
yours Peter0003
Either re-tap the hole a size up, or helicoil it, or if not enough metal, then replace the distributer.
Recover the original screw & recut a usable cross head slot in its head in order to reuse it, using a junior hacksaw.
That is, improvise, adapt & overcome a minor snag to keep on rolling along.
Make your own good luck. :cool:
