Reverse Light
G
Greeny
On my K11 i noticed my reverse light was out so i did as any1 else would and changed the bulb and fuse but it still does not work, any1 got any ideas???
only other thing it is likly to be is the switch on the gearbox, have a look and you will see a 2 pin wireing plug on the gearbox.
thats it but i dont know if its on the front or back of the box on a K11
same!
I have the same problem, only noticed yesterday don't know how long its been like this. how do you fix this? the haines manuel isn't much help.
Also, i can't find my reverse light fuse? its not on the list where all the other fuses are.
I hate these problems... once youve ruled out the common factors and it is still there you are forced to investigate harder... could be a short wire somewhere... or a relay... if you still havent sorted it get the Nissan Computer connected and see what it says... but I think it may just be rust or a poor connection... did u find out??
Thank God you're not like some other guy I was driving behind yesterday. His indicator lights were coming on when he braked!!! Lord have mercy.
