Replacing locks?
My locks are now officially busted, driver side is stuck unlocked :( but the other three doors can be locked from the inside, front passenger lock does not work with the key either though. How viable is it to change the lock on the driver door?
Dead easy. Remove the door trim then pop off the plastic clip holding the lock to the unlock bar. Then slide off the spring clip holding the lock to the door. Reverse the order to put everything back. 30 minute job. 15 min when you've done it once.
