Replacement Wheel Studs
Allo all!
Searched the forums and can't find the specific answer I'm looking for, so hoping someone has a spare wheel stud to hand to measure.
Standard K11 Wheel studs are:
- M12, 1.25
- 39mm long, with 23mm of thread.
- 14.3mm spline.
As far as I can tell, its the same studs front and back.
BUT, what is the length of the spline - is it 11mm?
Ojo, si vamos a utilizar tuercas ciegas, tener en cuenta si ponemos llantas de aleación de aluminio o son de acero. Las de aluminio son más gruesas, por eso hay que tener en cuenta la profundidad del perno.
