Removing CD/Radio from 2002 K11
I need to remove the CD/Radio from the Dash to get its serial number as I have lost the Radio Code..Can anyone explain how this is done? Many Thanks for looking Michael
1. Remove the ashtray
2. Remove 2 screws from behind that
3. Under the lip under the heater controls, there should be 2 more screws, take them out
4. Pull the complete plastic facica off
5. There should be 4 screws holding the radio in, remove them
6. Radio falls out
7. Good times!
Hope that helped! :)
No bother! I wouldn't know how to go about getting the code because the only times I've pulled my radio out is either to replace it or just plug it right back in after! It's worked no problem everytime I've taken it out though.. I can't see why yours should ask for a code?
Maybe someone will shed some light about it hopefully!
You'll need to make note of the part number and serial numbers to get the code.
You can use a free app for your android device (phone/tablet) that calculates the code (but only for blaupunkt radios)
Should be along the lines of BP**********, 7********* ;) so you know what you're looking for
Guy
Has gone over to the oily side...
I do Jen but it only accepts 4 digits so it's a bit of a chocolate teapot really :( .
