Recommended engine oil
That's probably ok, or every 6000 miles. The fully synthetic oil should cope if you forget but regular changes is the way to go. The micra sump isn't all that big and small cars are more likely to be doing short urban journeys which is harder on the oil anyway.
Thanks for the info , it's much appreciated , this is my first car as I usually ride a motorcycle , so I wasn't sure how often to do the oil change .
