Rear window washer switch sprays on the front windscreen
So.....as the title says, my window washer on the rear window doesn't seem to work. When I twist the switch on the stalk, it sprays water on the front windscreen. The front spray also works normally when pulling the stalk forward. Any ideas? o_O
Blocked pipe , or washer
Or like mine when. The rear washer jet is frozen it does that
Open the boot , near side bung at the top of the tailgate pull that out and you will see the pipe or if on a pre coil pack you can just pull the pipe off the inside of the washed at the top of the boot window and well blow or see if its blocked
That seem to like to block up cause of dirt build up over the years
