Rear Cluster Gasket
Hi guys. Anyone know what that icky black stuff that seals the tail clusters is? I need to reapply mine after swapping the lights over. I was also thinking of using some thick neoprene or something similar to make a removable gasket. Anyone done this before?
Geobond roof sealant will do the trick mate..can buy it from most builders merchants:)
OP
OP
cgten
Yeah I'd like to be able to remove them every now and again. I'm leaning towards making a solid gasket like a lot of other cars do. Less mess and easy to remove.
the factory used dum dum eh, i usually pull it off and roll it into a sausage again (re-use it)
I never thought I'd hear that used again, the fitter at work introduced me to it about 35 odd years ago....still make it ??? good stuff.
Used it on fitting windscreens.
