rear brakes
S
scoot
Guest
:k10: hi freed off the front calipers there was a lot of rust under thepad shims and also the last person hadnt put any copper slip on the pads and they had stuck on one side also the sliding pin on one side had seized got that free then greased it up with some silicon ht grease suitable for rubber i just need to free off the rear drums now had a try at it today but no joy looks like ill have to use a slide hammer to free them :down: and it started to rain so ill try tomorro if dry ! thanks all who replied(Y)
a sharp crack with a decent hammer does wonders for rear drums, either that or a hamer and a big chizel to knock them off.
A slide hammer on a wheel nut thread won't work unless you take the bearing out too as the drum is a seperate thing all together.
