RADio code
John_D
Radio Code Guru
Hey guys,
like many others before me I have trouble with my radio code... I had to disconnect the battery, radio locked, can't find the code...
Could anybody help me? The Serial Number is BP334936386693 8635123392.0
Thanks!
Hi, try 2971 or 0971.........
Hello, can someone help me ? I need a radio code for my mimi. The serial number MDHFBUK13U0763037
THANK YOU IN ADVANCE
Hi
Like all the others I have recently purchase a nice low mileage micra only to find the radio doesn’t work because it needs the code.
I have take out the radio and the make and serial numbers are as follows
Blaupunkt
BP538469510553
7645384318
Your help will be much appreciated
John_D
Radio Code Guru
Hi
Blaupunkt
BP538469510553
7645384318
Hi, try 6115 or 0115......
I bought a second hand micra k13 with no radio code and it needs a new battery. I took the panel off and the numbers from top to bottom on the radio are:
28185 1HAOA
PN-3201M-B
serial number CL0930B9052837
Any help would be appreciated.
Update: after a lot of searching I found a program called clarion code calculator, but will have to wait until my new battery arrives to test it.
Update: Well, changed my battery and the radio is still working. It didn't ask for a code.
Hi, I have a micra with a radio with serial number CL0816 9 0084039
(Nissan part number 28185 BG10A, model number: PP-3001M-B).
Is it possible to get a code for this radio?
Many thanks!
Hi, I’m really struggling to find a radio code for our micra the serial number is BP334947290506 and the second number is 8635123392 any help would be greatly appreciated! Thank you in advance! Max.
Hi trying to sort my radio code after a battery change and no code in handbook.
BP538464179928
7645384318
Many thanks in advance
Hello, like loads of people I am asking for help in obtaining the radio code for my 2005 Nissan Micra. Can you help please?
my number is BP3349 58119385 but the only other number on my "radiopass" is 28185AX613 but others all seem to be numbers. Is this the serial number of is there somewhere else I can find this (aside from pulling out the radio which I could give that a try). Thank you for your help
John_D
Radio Code Guru
Hi, from your 'BP' serial number you should try 9668 or 1668....
Hi John_D,
Looks like you are the person to ask about this so thanks in advance for any help you can give.
Flat battery on my Navara and then the radio code prompt.
Serial: DW24N07145
Part: 28185 BH30A
I'm sorry but I'm not sure if the O's are o's or zeros.
Again, many thanks!
Hi
just changed the battery on a 2005 Nissan Micra 1.0 and the code on the radio pass doesn’t work
can anyone help?
BP3349 58118118 6867
7643349318
Thanks in advance
