RADio code
John_D
Radio Code Guru
#5
Thankyou I’ll try it, the “wait 1 hour” is on at the minute :(
Don't forget that to get rid of the 'wait one hour' message the radio has to be turned ON and the ignition turned ON, so best bet is turn on the radio and go for a drive till the message disappears.........
#6
Thankyou I’m off for 1 hour now :) I’ll let you know.
#12
Hallo there
1st time in here.
2 months ago got a lovely Micra K12 and forgot the interior light on at the weekend and guess what? Battery dead and asking for code.
Here is info of my radio and hopefully someone help PLEASE
BP3349 4 7252100
7 643 349 318
Many thanks
John_D
Radio Code Guru
#13
Hallo there
1st time in here.
BP3349 4 7252100
7 643 349 318
Many thanks
Hi, if your interior light took your battery down, over a day or two, to a level that killed the radio memory then you need a new battery!
The code for your radio is 1798, write it down and keep it safe as you undoubtedly will need it again soon ;)
#15
Hello, can somebody help me with a radio code?
BP6340V3592614
7 646 340 318
The radio currently is displaying "Secure". I have disconnected the battery and will leave it for a while to see if that clears this, but if anybody has a better idea how to get this back working please let me know. I have just read somewhere that if I leave the car running for 1 hour it should clear the Secure message and will ask for the radio code again, which I currently don't have, so if somebody can generate it for me I would appreciate that.
Thank you in advance.
John_D
Radio Code Guru
#16
BP6340V3592614
7 646 340 318
Hi, as I understand it the 'Secure' message is on step up from 'Wait 1 Hour' , not sure how you get rid of that one. :0(
However if you do get it back to 'Code' then the numbers that you want are either 7349 or 1349....
#17
Hello,
Disconnecting the battery didn't help, but leaving the car running with the radio on (displaying Secure) did the trick, after about 50 minutes it asked for the code, and worked straight with 7349. Thank you very much for your help.
John_D
Radio Code Guru
#24
Hi
I'm looking for a radio code for my Mothers Micra 1.2 S 2003
Blaupunkt
BP 33493349318
7643349318
Many Many Thankyous in advance
Lee Green
One number missing from the 'BP' serial number, there should be 12 numbers after 'BP' (sometimes there is a letter in the middle).......
#33
Hi,
Can anyone help. I have lost my card with radio code and contacted Nissan who gave me another code and it is wrong. The serial number on screen is DW3AN20764 part 28185 3HN4B.
#34
i I have no idea which is the serial number >//?
On the radio is the following
BP334936356522
Then Nissan 7 643 349 318
e1 022458
28 185 AX613
HP-3064
55610021062
nissan MM CD-K (BLK)
Is any of those the radio code ????????
John_D
Radio Code Guru
#36
Hi
Can you please provide me with code for my 2010 micra
I have the following numbers
K123243312
74124e584984
28065135
Don't recognise those numbers for code generation. I can only generate codes for BlauPunkt manufactured radios and I need the serial number, found on the back of the radio, starting with 'BP', followed by 12 numbers.....
#39
Bf tampered with the battery and now my radio is requesting a code I never had a handbook or anything with car how do I obtain the code pls? I can’t cope driving round in silence much longer please help!!!!
#44
Hi guys, I have taken the battery out of my car (Nissan note n-tech ) and my radio is locked out .Need a code please .
Serial number: 2382370
Device number : 7612830051
Any idea how i get the code ?
#50
Hey guys,
like many others before me I have trouble with my radio code... I had to disconnect the battery, radio locked, can't find the code...
Could anybody help me? The Serial Number is BP334936386693 8635123392.0
Thanks!
