sr_steve Aug 9, 2012 #1 In the middle of fitting my quickshift but I'm a bit loat. Does anyone know what to do?
karlj Aug 9, 2012 #5 In the car: remove gear knob and gaiter remove plastic surround unbolt the small cage around the gear lever Under the car: remove the second cat (if you still have it) remove the heat shield that's above it (again if you still have it) unbolt the gear lever from the selector fork Back in the car: remove gear lever with cage Installing quick shift is just a case of doing it it reverse !!DISCLAIMER!! I did this some time ago, approx 2 years so this is a ROUGH guide
OP OP sr_steve Aug 10, 2012 #9 I'll put one up tonight mate after work, Kenny Jim bling said it looks different to what he put on his
