Quick lunchtime question
Picked up a 1.4 last week and hoping someone can quickly tell me what sized bolts I need to mount it on an engine stand?
I can check when I get home and remove the transmition but figured it was worth an ask as i’d then be able to pick them up over lunch.
I used 4-off M10x1.5, 75mm long. The one at the back of the block isn't threaded, so you'll need a nut and is a bit tight at that length but it's fine.
So I have it mounted (mostly)but the engines slightly too small for the stand I picked up for my old Land Rover. It gets the three threaded points (at weird angles) but doesn’t reach the unthreaded.
3/4 on a 700kg rated stand is fine right?
