Quick coil plug wuestion
pork
Can someone confirm which wire is what?
Using my own ecu and loom, and having a couple of issues, so just checking my wiring
I've got it wired up 12v-earth- signal
Might be the problem then.
I keep blowing the coil fuses as soon as I power up the ecu
, but only when I plug in cylinders 3 and 4.
The coils are paired up inside the ecu
That's how they are in the ecu,
1 is parralell to 3
2 is parralell to 4
but I guess it's down to where you distribute the wire to whatever cylinder.
Ecu can do up to 12 cylinders, with each driver power ring multiple coils....apparently
Cylinder 3 and 4 I get continuity to ground constantly With probes in the live and on block
But if I've wired the plugs up wrong, that'll explain it
