Brother has a flat but no spare Will a K11 wheel fit the hub on a N15 Almera ??
S SplanK Site Supporter Sep 3, 2011 #1 Brother has a flat but no spare Will a K11 wheel fit the hub on a N15 Almera ??
OP OP S SplanK Site Supporter Sep 3, 2011 #3 yep - its a 1.4 Almera but I think the 1.4/1.6/2.0 share the same hubs, or at least wheels are compatible between engine sizes/models He has just found his spare under his sub but no jack *DOH* Will take the micra spare just in case Ta
OP OP S SplanK Site Supporter Sep 4, 2011 #5 Yep, as people have already said - confirmed yesterday that the K11 wheels fit a N15 Ta guys
OP OP S SplanK Site Supporter Sep 4, 2011 #7 Stani1029 said: Not if its a gti though Click to expand... why... you can swap wheels between N15 models (my brother has GTi wheels on his 1.4 Almera)... Unless this is a reference to the brakes been larger on the GTi (using 280mm discs) which require a min of 15" wheels to fit over the calipers....
Stani1029 Club Member Sep 4, 2011 #8 Pcd's are the same but the brakes are different and if youve only put 1 micra wheel on and the car is in use then watch you dont get pulled over and get points if the wheels are different sizes
