if you drop it to 3K you will have a big hole in the power band.
Dont even look at the power FC they are not as good as made out, and totally unsuitable to the ST!!
Its possible its not right, there is ofcourse lots to be wrong, however I couldnt say without seeing it. One thing I do know tho is that if the turbo on its own at 3000 rpm doesn't do all that much so there is no point turning off the s/c if you want to make it go faster, as the opposite will happen. if you disconnect the supercharger plug thats above the pully and go for a drive you will see what I mean.
Ed
well, I have been working with a few others and it looks like we may have found the supercharger timings.
NOT ONLY THIS it looks like we will beable to dump the airflow meter and goto a MAP based system. For us this means NO restriction on the intake to the turbo. FANTASTIC!!!!!!!
I'll let you know more soon, I need to do some testing first.
Ed
