Question About Amplifiers- Basically HELP!!!
W
winstonerogers
Hello,
I have pioneer 7700
2 amps, one going to a sub and the other going to 6x9s.
the headset has 2 rca out puts,
both my amps have 1 rca input but no out put.
1 amp (SUB) JBL GTO 2000 (400w)
1 amp (6x9) Sony XPLOD (250w)
both rca output are occupied on my headset, how do i add another amp?? its actually an active sub?? HELP ASAP
Thanks in advance
ALL IN A K10
i dunno if this is right but .....
wouldnt these connectors decrease the current in the signal wire and so the amplifier would output less volume (due to the current being decreased)
how many amplifiers could you run using this method of splitting the signal wire?
You got speakers in the front then? i cant see why the RCA's would be occupied otherwise.
to have 2 speakers in the dash(above the glove box) i have 2 speakers on the doors (front(one on each)).
2 amps in the back, one to 6x9s and the other amp to sub
useing those spillters is fine if you hav a amp with a output all it is ,is the conections bridged over so it does exctly the same thing , thats what im doing for my 2 amps and it works a treat
same here, a 4 channel amp for two sets of 6x9's and a 2 channel amp crossed for the sub, both connected via splitters to the 2 pre outs on the head.
